Can't start FLUENT with Serial - "No cached password" |
Rep Power: 0 ![]() |
Hi!
I just started out learning ANSYS Fluent and I came across a problem. I got the ANSYS Student version, if that's important. I can start Fluent with no problems when I set the processing options in the launcher to "Parallel" However, when I try to set it to "Serial" and start Fluent 2 things happen: a) Fluent gives me this message: "WARNING: No cached password or password provided. use '-pass' or '-cache' to provide password" b) It completely freezes and I have to kill it via Task Manager. What am I doing wrong? Why is it working with parallel but not serial? I tried installing the Intel MPI, even though I have an AMD processor. I then tried executing mpiexec -register, but even this didn't help :/ What should I do? EDIT: Unfortunately, the parallel one doesn't work now either. Please help, I need it for a project ASAP :/ |
Miguel
I had the same problem, this was my solution:
-Disable Windows Firewall -Run Fluent -Acept all connection permissions -Able windows firewall -Enjoy (In my case, I have to disable firewall before running Fluent) |
Amartuvshin
It works. Thank you very much
s Gray
I also have this problem when trying to start fluent (both through workbench and using just fluent directly). I'm using the student eddition of Ansys 19.0. I have tried disabling the firewall as suggested however that only caused fluent to incounter further errors when trying to start. Does anyone know of an alternative solution? |
Fluidflow
Rep Power: 10 ![]() |
I have the same problem.
what do you mean from "-Accept all connection permissions"? What should I do? |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
FLUENT doesnt start | srinivas | FLUENT | 1 | May 7, 2007 12:15 |
new to fluent; where to start? | inderpreet singh | FLUENT | 4 | September 5, 2006 11:53 |
Fluent License Manager Start Up Script | Amadou Sowe | FLUENT | 1 | August 7, 2004 14:09 |
