December 10, 2017, 14:24 |
Best way to import photo
Artūrs
Hello!
1. I am looking for advice for best way how to import this kind photo in ansys. It is asphalt with rocks and bitumen. http://www.bildites.lv/images/gajxp3...1/original.jpg. 2. I used photo processing programm imagej/fuji and got white/black picture. 3. After that I used adobe ilustrator to get photo contours and saved file for autocad. 4. After that I have option to import this file in ansys. Here is small result. http://www.bildites.lv/images/b3gnd4...8/original.jpg But problem is that programm is not meshing all area in one time(it takes lot of time to mesh with small areas. I have to define two diffrent parts. First is area around holes and second is all holes with the same properties. 5. Is this best/easiest way how to get picture in ansys? 6. And is there some option to write code which will mix rocks to get diffrent results? |
Just points and no curves in ICEM CFD import | xjotek | ANSYS | 0 | November 16, 2017 16:25 |
I developed an FEM toolkit in Java: FuturEye | nkliuyueming | Main CFD Forum | 7 | January 29, 2016 13:28 |
[PyFoam] library import error | 00Sibbe | OpenFOAM Community Contributions | 5 | October 15, 2014 11:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
