January 23, 2018, 05:49 |
Cant select nodes for boundary conditions
Win 10, x64, Ansys Workbench 17.1
I have a simple cylinder model (shell elements) & want to fix the nodes at the bottom of the cylinder. So I created a Named Selection which contains the nodes to be fixed by clicking through 'Named Selections -> Node -> Box Selection -> Scoping Method -> Geometry Selection -> select nodes in the graphics space -> Apply'. Next I click through 'Analysis settings -> Supports -> Fixed Support -> Scoping Method -> Named Selection' but no Named Selections appear in the pull down menu?!?! What am I missing here? |
node boundary, selection |
Export boundary setting in Fluent 14.0 | asal | FLUENT | 4 | September 28, 2017 09:40 |
32 Cores Mini-Cluster, 2 Nodes vs. 4 Nodes performance | Courageous | Hardware | 3 | July 7, 2016 11:37 |
[ICEM] How To Select Number of Nodes For a Particular Length | Shomaz ul Haq | ANSYS Meshing & Geometry | 8 | February 29, 2016 13:04 |
[Other] select nodes | fariba | ANSYS Meshing & Geometry | 0 | May 26, 2014 00:36 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
