Utilising thin walls in "Boundary Conditions" |
November 18, 2021, 06:53 |
Rep Power: 4 |
I've set up my geometry using Design Modeller. I have a solid object which represents my fluid body, and I've created an external thin wall with a thickness of 0 from this object and combined these two objects as one part.
I've meshed this body, named the thin wall as a hot temperature source and named the surface of the fluid body (excluding inlet and outlet), as the cold walls. I can't select the internal sides of the thin wall as when I hide the internal body and try to select the internal sides, it just highlights the external faces. What I want to do is utilise this thin wall as a constant temperature boundary, and run a transient simulation so the fluid flow in the internal solid object (really confusing nomenclature - that doesn't help ), is heated by this thin wall over time. My issues are, I can't create a contact between the internals of the thin wall and the edge of the fluid body. I can also not see the thin wall in the "Boundary Conditions" table when setting up the simulation calculation. I don't understand why there is not just an option to set the wall temperature of the fluid body to a different temperature to the interior of the fluid body at the beginning of the calculation. I'm using Ansys 18.1, and all guidance would be much appreciated. |
ansys, boundary conditions, fluent, heat transfer, thin walls |
Thin Walls using blockMesh | varun | OpenFOAM Running, Solving & CFD | 6 | December 8, 2020 13:18 |
Distance between walls with thin wall/shell conduction | mir9283 | FLUENT | 0 | May 16, 2018 03:49 |
[Commercial meshers] Thin Walls Conversion from Fluent Mesh | Isaac | OpenFOAM Meshing & Mesh Conversion | 1 | March 4, 2016 12:08 |
shell conduction @ thin walls | Jiri Beran | FLUENT | 0 | May 18, 2008 14:08 |
Thin Walls in CFX5 | Dave Hargreaves | Main CFD Forum | 1 | April 14, 1999 12:08 |
