Ansys Workbench (SIG$ILL) error
Old   February 13, 2018, 09:20
Default Ansys Workbench (SIG$ILL) error
valerio
peinakatsuki is on a distinguished road
Hi everyone, I'm using Ansys Workbench for a static struttural problem .
After I imported cad model, created a mesh, defined constraints and forces, finally I tried to solve, but getting the following error:
An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
After I checked the solver the following error comes up:
*** ERROR ***
"An unexpected error ( SIG$ILL ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program."
I got the same error using 14.5 and 16 Ansys version.
Does anybody know what could be the cause for it?
peinakatsuki is offline   Reply With Quote
Old   November 26, 2021, 02:31
Default Amd
Alexandre Sampaio
AlexFlow is on a distinguished road
Are you using AMD processor? CPU
AlexFlow is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
