Negative Volume in fuel injection system
Old   April 17, 2018, 16:30
Default Negative Volume in fuel injection system
Abhay
abhaymh is on a distinguished road
I have a combustion chamber, with a fuel injector pipe leading upto it. There are many cells with negative volume near the interface of the combustor wall and the inlet pipe.
The .blk file : https://drive.google.com/open?id=103...uVSVkn5kXy9nxD
The .tin file : https://drive.google.com/open?id=11b...VAQyZJYEUWy7gw
abhaymh is offline   Reply With Quote
ansys, combustion chamber, icem, meshing, multiple blocks
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ANSYS Meshing] Small mesh error: Zero or negative volume for elements. [Explicit dynamics] matin ANSYS Meshing & Geometry 0 September 14, 2017 20:19
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
remeshing due to negative volume error Doginal CFX 1 August 21, 2011 21:50
