May 16, 2018, 10:33 |
How to get dimensions of a tutorial file
Kaimynas
Rep Power: 8 |
Hello, i want to get dimensions of a cfx tutorial 30. Coal combustion but i cannot check it because there is only mesh file which i cannot use for checking all the dimensions, is there a simple way of doing that or does anyone maybe know the dimensions of this tutorials geometry, thanks
May 20, 2018, 23:15 |
Coal combustion - furnace dimensions are clearly mentioned in the figure. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
