meshing problem
Old   November 4, 2018, 23:51
Default meshing problem
Zainab1 is on a distinguished road
Hi
could anyone suggest a way to mesh a cylindrical tank with a spiral heat exchanger?
I tried almost eery possible mesh command and I still don't seem to get it correct, still receiving floating point error
I used swept mesh for the spiral
and normal curvature mesh for the tank
still getting floating point error
tried automatic method also, still no luck
please help
Zainab1 is offline   Reply With Quote
Old   November 5, 2018, 15:20
Gert-Jan
Gert-Jan will become famous soon enough
What program do you use? Ansys. But Ansys-what?
You have to be much more specific if you want help.
Also, wrong forum. Go to Geometry and Meshing.
Gert-Jan is offline   Reply With Quote
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 07:04
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
