January 4, 2019, 05:46 |
Ansys Polyflow - problem with simulation
Adrian
Hello, for several days I started using the Ansys Polyflow program. I set Geometry, Mesh, Setup and when I want update solution I have a problem. I am sending the description below.
"At least one bad element has been detected in the mesh. ******* The worst has the following feature (s) ******* Negative Jacobian in element 45, (x, y, z) = (0.007445, 0.03399, ********* 0.005009). ******* Too small angle in element 45, (x, y, z) = (0.008113, 0.03491, ********* 0.005691). ******* Too big angle in element 108, (x, y, z) = (0.00317, 0.021182, ********* -0.0013973). ******* Non-convex element 54, (x, y, z) = (0.005922, 0.031249, 0.003263). ***** This can lead to local inaccuracies and possibly convergence ***** difficulties. It is strongly recommended to fix the mesh. " Can anyone help me? What can I do to get rid of the error. Greetings, Adrian |
ansys polyflow |
Problem in Clod Flow Simulation of IC Engine in ANSYS | Rajat Arya | ANSYS | 0 | August 14, 2018 05:55 |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 09:16 |
about valve closing problem during ANSYS FSI simulation | ivy | CFX | 4 | June 8, 2011 21:01 |
Multiphase radiation in Ansys 10 problem | Luk | CFX | 2 | June 5, 2008 11:31 |
