Can anyone help Matlab figure data to ansys ??
Old   December 26, 2017, 16:34
Default Can anyone help Matlab figure data to ansys ??
Mohammed Sorwar
Sorwar22 is on a distinguished road
I have used the method of characteristics method to create the divergent section of the nozzle i now want to run the simulation in ansys fluent after slight modification in design modeller. Does anyone know how really stuck on this for quite some time any help would be appreciated thank you in advance
reagrds
Sorwar
Sorwar22 is offline   Reply With Quote
Old   December 27, 2017, 07:01
juan4815 is on a distinguished road
I'm not sure about your question, do you mean to export your nozzle shape from matlab (points data) to design modeler, so that then you can run it on fluent, or is it something else?
If the former, at least in space claim you can create a curve based on a function so you could try to create an interpolation in matlab (apparently you can't give points coordinates directly) with a suitable function and then used that to create the geometry.
juan4815 is offline   Reply With Quote
Old   December 27, 2017, 07:24
Mohammed Sorwar
Hi Juan,
Yes i am trying export the nozzle shape as data points into design modeler / solidworks (CAD) i have heard i may have to export the data points into Microsoft excel as there may not be a way to directly take the data from matlab to ansys if you have any ideas on how this can be done please let me know any advice would be appreciated
thank you
Old   February 21, 2019, 09:11
Default Matlab to solidworks / Ansys
Mohammed Sorwar
Has anyone been able to find a compatible way to import the matlab into figure into Solidworks or Ansys Fluent directly to be used immediately following import.
In this case i was trying to import the nozzle figure from Matlab to Ansys or via Solidworks any help would be appreciated.
Old   February 21, 2019, 10:48
M
AtoHM is on a distinguished road
Print those points out into some csv or text file and import it in Solidworks or DesignModeler. I have done both in the past, it works. You will find guides or hints on the steps via google.
AtoHM is offline   Reply With Quote
ansys, divergent nozzle, help me please, matlab
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
EM Force data mapping from Maxwell to ANSYS Mechanical vahidasadzadeh ANSYS 0 October 25, 2015 06:01
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
