999999: mpt_accept: error: accept failed: No such file or directory |
May 20, 2019, 11:31 |
Rep Power: 6 |
Hi everyone,
This is urgent. I am currently using ANSYS 19 and I want to run some simulations using the DTRM package in Fluent. I can run this very simple simulation (a cube with a heated side) in my personal computer (which has a student version of ANSYS 19), but when I try to run it on a server, I obtain the messages shown in the attached image. To be more specific, I can load the mesh on the Fluent, but when I choose the DTRM package and select the folder where I want to save the .ray file, the messages shown in the picture appear and 3 seconds afterwards, the window closes. I really doubt I do not have the sufficient rights to run generate the .ray files. I have even checked that every file is where it should be comparing the folders in my PC and the server. Just the .ray file is missing. It is strange because I can even run other radiation models on the server, but I cannot run the DTRM package. Thank you in advance Last edited by helios95; May 21, 2019 at 03:53. |
May 21, 2019, 02:48 |
Gert-Jan
Rep Power: 27 |
Why not try the fluent forum?
July 1, 2022, 05:54 |
Asma
Rep Power: 3 |
Did you find a solution to this error ? |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
