Two boundary conditions on one surface
Old   August 16, 2019, 11:13
Default Two boundary conditions on one surface
menachilis is on a distinguished road
Hello everybody,
I am trying to simulate a high heat flux part of a reactor, and at some surfaces i have two different surface heat loads (W/m2) which i have to consider. I cannot just add the values in those areas since they are profiles(x,y,z coordinates and heat value).
Does anybody know if this is possible? I am trying to create the named selections for those boundaries while meshing, and since they overlap at the surfaces with both heat-loads, i can't even export from Meshing.
Summing up, i would like to apply two surface heatloads on a single surface
Any help is kindly appreciated!
Thanks
menachilis is offline   Reply With Quote
Old   August 28, 2019, 23:13
Javier Rose
javierrose is on a distinguished road
Originally Posted by menachilis View Post
Hello everybody,
I am trying to simulate a high heat flux part of a reactor, and at some surfaces i have two different surface heat loads (soundcloud downloader) which i have to consider. I cannot just add the values in those areas since they are profiles(x,y,z coordinates and heat value).
Thanks
One way can be you apply inlet boundary condition for time steps you require. Then stop the run, modify the boundary condition and resume the run. After modifying the boundary condition, do not initialise. Directly start run.
javierrose is offline   Reply With Quote
Old   August 29, 2019, 04:58
M
AtoHM is on a distinguished road
You can import the heat loads as profile data into Pre. Then you have an expression referencing your profile data.
Write another time-dependend expression like "If(t <= 1 [min], profiledata1, profiledata2)" referencing those profile-data-expressions. You could use step-function as well.
Then apply your time-dependend expression to the BC.
AtoHM is offline   Reply With Quote
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
