Remeshing for two different domain in Dynamic Mesh |
March 11, 2020, 13:10 |
bora
Hello everyone,
I have two domain as solid plate and room in Fluent and a velocity inlet in the room. I would like to move the velocity inlet and see the temperature differences on the plate. In order to see that I´m using dynamic mesh with a UDF code. Everything is working very well till this part. Remeshing and Smoothing modes are turned on and I set the velocity inlet as a rigid body and others as deforming bodies. Furthermore I have 6 prism layers between the solidplate and the room. However, when I preview the mesh motion prisim layers do not deform and they just stretch, thus after a time step it gives error. I played with the values in remeshing and deforming sections but could not find the right way to solve the problem. Could anyone have any idea how could I solve this problem? Thanks in advance. Best regards |
dynamicmesh, quenching, remeshing, smoothing, udf |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
Dynamic mesh Remeshing | Saman95 | FLUENT | 0 | June 18, 2019 02:06 |
Dynamic Mesh: Remeshing doesn´t work properly | maccheese | Fluent Multiphase | 4 | June 7, 2018 05:56 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
