Result dependent boundary condition
Old   August 29, 2020, 19:04
Default Result dependent boundary condition
Konstantin
KoBra is on a distinguished road
Hello everyone,
i want to do an thermal transient simulation in Ansys where the boundary condition on an solid part is an heat flow, which is depending on the temperature on the same surface. So in reality the system measures the temperature on the surface (T) and changes the heat flow depending on it to regulate it on 60°C:
Q = Constant [W/K] * (60 [°C] -T)
So the system has to change the heat flow in each time iteration depending on its design.
Is someone common with such simulations? The preferred solution for me would be one in Ansys Thermal-transient Analysis tool but CFX is also ok.
Thanks in Advance
Konstantin
KoBra is offline   Reply With Quote
Old   September 10, 2020, 22:06
Erik
evcelica is on a distinguished road
Seriously? The form of that equation doesn't look familiar to you?
I'll give you a hint: It's one of the 3 forms of heat transfer.
I'm really surprised there were 136 views when I posted this, and yet no answer for you.
Let me know if you need more hints, but you should really be able to get this.
evcelica is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Robin boundary condition containing two dependent variables babakflame OpenFOAM Programming & Development 0 February 25, 2017 20:04
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 06:09
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
