streamlines showing in area that didn't melt!
Old   May 15, 2021, 13:10
Default streamlines showing in area that didn't melt!
mody
shatarah is on a distinguished road
hello . i used Ansys 19 workbench to make a 2d simulation of the melting of a substance in a container (with fins) from the left side . i wanna see the convection streamlines at 50% melting .
The problem is Ansys results (post process) shows velocity streamlines everywhere even if it has a value of zero as you can see in pic 1. I only want to see streamlines in the melted zone because a big part of the right area is still solid and it doesn't make sense to have streamlines there.
btw if I try to see velocity vectors they make sense and only show up in the melted zone as you can see in pic 2. the substance is defined as fluid in setup but its initially below its melting temp .I would appreciate if you could help me
shatarah is offline   Reply With Quote
ansys, post procesing, post process, streamline, streamlines
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
Concentrated Streamlines versus Higher Velocity eucalyptus Main CFD Forum 1 October 27, 2017 11:54
Scripting Projected Area to Reference Area mgpaul FLUENT 0 February 4, 2016 17:41
how to use UDF to obtain the thred of the interface between the liquid and the wall? hellowqy Fluent UDF and Scheme Programming 8 December 17, 2015 10:03
[OpenFOAM] Problem with cell area calculation in a slice daniel87 ParaView 5 October 24, 2015 16:18
