December 14, 2020, 00:43 |
Gas liquid Absorption/ mass transfer
Evan Marquez
I want to simulate a riser system, a pressurized gas( Co2/methane) being injected into a pressurized vessel full of liquid (internal olefin) The pressures are the same. The gas bubbles go through the liquid at a inlet flow rate and then exits the system ( atmospheric pressure). As the gas bubbles go through, some will dissolve into the liquid. I’m trying to find the rate at which the gas dissolves into the liquid at different pressures, bubble size, and inlet gas velocity. |
Unrealistic simulation of mass transfer from liquid to gas using reactingTwoPhaseEule | yaoyn | OpenFOAM | 1 | May 15, 2019 18:37 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
