UDF Species of each phase
Old   April 8, 2021, 17:20
Default UDF Species of each phase
U1990
U1990 is on a distinguished road
I am writting a UDF code to simulate chemical reaction between phases. However, I can not found information (macro or routine) about to select a specific specie of a phase.
For example:
Species1(phase 1) + Species1(phase 2) ==> Species2(phase 1)
How can I use data specifically from Specie1(phase2) in a UDF??
Thanks.
U1990 is offline   Reply With Quote
Old   April 8, 2021, 22:43
Yasser Selima
Yasser is on a distinguished road
Domain *domain;
Thread *mixture_thread;
Thread *phase1_thread;
Thread *phase2_thread;
domain = Get_Domain(1)
mixture_thread = Lookup_Thread(domain, zone_id);
phase1_thread = THREAD_SUB_THREAD(mixture_thread,phase1_index);
phase2_thread = THREAD_SUB_THREAD(mixture_thread,phase2_index);
begin_c_loop(c, mixture_thread)
C_YI(cell, phase1_thread, specie_index)
C_YI(cell, phase2_thread, specie_index)
end_c_loop(c, c_thread)
Yasser is offline   Reply With Quote
Old   April 9, 2021, 01:51
U1990
Originally Posted by Yasser View Post
Domain *domain;
Thank you very much for you reply. However, I have another question:
Does it works with Eulerian multiphase model? and if it is, The code is the same?
Old   April 9, 2021, 06:11
Yasser Selima
I want to clarify that this is not a whole code. This is just a procedure to access the mass fraction of specie in a phase. By recalling the phase thread and using Y_CI
The answer to your question is yes, it should work with Euler-Euler model
reaction, species, udf
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 17:46
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 09:24
Direct numerical simulation of species transport equation with phase change Pmaroul Main CFD Forum 2 October 12, 2018 16:02
Phase change UDF rampal Fluent UDF and Scheme Programming 7 January 27, 2017 23:00
Unexpected species increase in discontinuous phase CeesH Fluent Multiphase 0 August 6, 2014 05:41
