System Coupling analysis, Structural / Fluent / ACP |
January 30, 2021, 17:35 |
Benjamin G.
I have been experimenting with Ansys System coupling analysis using Transient structural and Fluent on various models successfully. I am now trying to run the same simulations on a composite model, therefore integrating ACP Pre. I am blocked in the Transient structural part, at how to define the "Fluid Solid Interface" for a composite model from ACP Pre. Composite models appear planar, without thickness. ACP Pre only defines the thickness for the mesh, not the model. Anyone has experienced integrating composite in a Structural / Fluid coupled analysis? Your help is appreciated. Benjamin G. |
September 14, 2021, 23:17 |
Rep Power: 4 |
Doing a similar simulation, did you ever figure out how to incorporate ACP into Sys Coupling?
September 15, 2021, 01:46 |
Benjamin G.
No I haven't found out how. And I would still be interested in finding a solution. |
September 20, 2021, 00:09 |
Rep Power: 4 |
You should be able to create system coupling regions on imported ACP solid models. If you import the mesh as a solid model from ACP, the mesh will be modeled with solid elements (instead of shell elements) and each surface will be selectable for system coupling regions.
My issue is more in volumetric transfer of temperature, let me know if you ever come across that. |
acp (pre), fluent, system coupling, transient structural |
Fluid Thermal 2-way System Coupling Dynamic Memory Allocation Error | Tiger23 | CFX | 6 | February 8, 2020 00:25 |
coupled fluent and structural analysis | mahdi1569 | FLUENT | 0 | April 2, 2016 13:39 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
How can I track the progress of FLUENT when running ANSYS System Coupling | yhy20081016 | FLUENT | 1 | June 4, 2013 12:03 |
CFX vs. Fluent for coupling analysis | aspirany | CFX | 3 | January 20, 2010 23:25 |
