February 6, 2024, 03:47 |
Boolean function
eddy
Rep Power: 2 |
Hello, everyone.
I'm working on simulating the drag coefficient of a sphere. In DesignModeler, I can create a sphere and use the 'Enclosure' function. By employing the 'Boolean' function, I can generate the geometry for my simulation. However, in SpaceClaim, even after creating a sphere and using the 'Enclosure' function, I couldn't find the 'Boolean' option button... Can someone help me? I apologize for my limited English proficiency. Thank you for reading my question. |
February 6, 2024, 05:10 |
Gert-Jan
Rep Power: 27 |
Why not create a sphere and a box and then combine them using:
Design > Combine In this menu, you can join or subrtract objects. Whatever you like. |
February 7, 2024, 21:04 |
eddy
Rep Power: 2 |
Thanks, I will try it
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
