My "data file quantities" in Ansys Fluent is inactivated. |
March 8, 2021, 12:24 |
Can anybody inform me why My "data file quantities" in Ansys Fluent is inactivated?
When I want to calculate my problem in Ansys/Fluent, I need to set the Data File Quantities for calculating the Nu and other numbers but this tab is inactivate in my Fluent. I uploaded the figure of my software here. https://pasteboard.co/JRGXfJ7.png |
August 9, 2021, 12:04 |
Rep Power: 4 |
Hi, did you find the solution?
January 5, 2022, 09:36 |
Bruna vitoria chagas carneiro
Hi, did you find the solution?/2
January 10, 2022, 04:22 |
Felix
I get the same problem. The tab is inactivate in my Fluent.
poppy playtime |
January 20, 2022, 03:05 |
mariyam ali
Rep Power: 4 |
I am facing the same problem. can you please share the solution if you have solved it?
January 20, 2022, 09:19 |
Gert-Jan
Rep Power: 27 |
maybe you should first initialize the solution?
January 20, 2022, 10:55 |
mariyam ali
Rep Power: 4 |
thanks for the suggestion. Ill try it.
June 10, 2022, 02:50 |
Murali Krishnamraju
Rep Power: 4 |
Initialize the solution first and then the option will get enabled.
November 19, 2022, 11:43 |
#9 |
Omi
The data file quantities option is still disabled after initializing the solution. What can I do about that?
November 19, 2022, 12:25 |
#10 |
Gert-Jan
Rep Power: 27 |
Use CFX......
November 19, 2022, 22:14 |
#11 |
Omi
How do you do that actually?
November 20, 2022, 01:43 |
#12 |
Gert-Jan
Rep Power: 27 |
If you have Fluent then CFX is just 2 clicks away.
Actually, the CFX solver has been built into Fluent in the last few years where it has become the standard since it has superior stability over the older Fluent solvers. So, if you use this in Fluent, you are using CFX in the background already. What remains is the crappy environment of Fluent. It is time for a complete makeover. |
March 17, 2023, 06:02 |
#13 |
anonymous
Rep Power: 3 |
HOW to use cfx ..i tried but my data is not able to transfer ..can anybody help me with data quantities file ...i wanted particle diameter check
March 17, 2023, 06:05 |
#14 |
Gert-Jan
Rep Power: 27 |
Ask the Fluent forum. Probably you'll have more success than here in this general ANSYS forum.
February 8, 2024, 04:23 |
#15 |
Pritam Mitra
Have you found the solution? If yes, please share with me. I am facing the same issue.
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
