ICEM Scripting
Old   January 3, 2022, 07:04
Smile ICEM Scripting
Aqib Aziz
aqibaziz11@gmail.com is on a distinguished road
Hello everyone!
I am working on shape optimization of an aircraft wing. I want to creat mesh in ICEM using scripting so that i can easily change grid for optimized shape. Can somebody guide me and share some tutorials or some user manual from where i can learn about ICEM scripting for generating mesh on a parameterized aircraft wing?
Your help is highly appreciated. Thanks
aqibaziz11@gmail.com is offline   Reply With Quote
Old   February 24, 2022, 07:25
Default Smile ICEM Scripting
charan
charan3007 is on a distinguished road
Originally Posted by aqibaziz11@gmail.com View Post
Hello everyone!
I am working on shape optimization of an aircraft wing. I want to create mesh in ICEM using scripting so that i can easily change grid for optimized shape. Can somebody guide me and share some tutorials or some user manual from where i can learn about ICEM scripting for generating mesh on a parameterized aircraft wing?
Parasolid part from solidwork, uses color coding with which you can read the model and mesh it with maximum element size, minimum element size and max deviation value. You can record script for doing the above process
charan3007 is offline   Reply With Quote
Old   March 5, 2022, 23:20
Default ICEM Scripting
Aqib Aziz
Thanks for your kind advice. Bro i used CATIA for generating geometry and then i am using ICEM scripting for mesh generation. I generated a mesh using recording method in ICEM. The actual project file is perfect but when i run the recorded script file, it does not generate the same mesh and gives errors like o grid not successful and error in script file. Kindly guide me what to do? Thanks
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 16:35
[ICEM] ICEM python geometry scripting eromon84 ANSYS Meshing & Geometry 0 December 12, 2015 11:39
[ICEM] Question about the use of ICEM tcl scripting lnk ANSYS Meshing & Geometry 9 January 16, 2013 09:24
[ANSYS Meshing] Icem scripting error davidwilcox ANSYS Meshing & Geometry 1 November 26, 2012 07:08
[ANSYS Meshing] Is there always fault in ICEM tcl scripting? lnk ANSYS Meshing & Geometry 3 July 14, 2012 15:05
