January 1, 2023, 04:02 |
Flutter analysis using Fluent (Two way FSI)
Umer
I am working on a project based on the flutter analysis. To do it, I am trying to do a 2-way FSI study with ANSYS-FLUENT. I am facing some problems. In my case, the study is at Mach 5.0. I need to get modal shapes of the geometry for vibration purposes. -Which solver is the most accurate one for a transonic flow? -In fluent, I have defined a velocity inlet and pressure outlet, but I dont know if this is correct in this situation. Should i use density based solver or pressure based? Thank you in advance. |
April 3, 2023, 13:50 |
MC
Rep Power: 5 |
It is hard to give advice without knowing the geomery a bit more in detail.
I assume you are referring to the fluid dynamic part (not structural): I can suggest density based solver. For the boundary conditions: you should specify the inlet Mach number with pressure-inlet and the pressure-outlet for the outlet. With pressure-inlet, you can set total pressure, temperature and supersonic (gauge) pressure. |
fsi, fsi 2-way, fsi compressible solver |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 19:10 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
How to do a one-way FSI analysis with ANSYS Fluent? | diwakar | ANSYS | 1 | July 31, 2015 15:16 |
FSI: How to transfer static pressure from fluent to ANSYS | momo_sjx | FLUENT | 0 | October 9, 2012 13:37 |
