ANSYS Workbench mesh crashes (ANSYSWBU.exe problem)
Like Tree27Likes
Old   June 24, 2010, 16:13
Default ANSYS Workbench mesh crashes (ANSYSWBU.exe problem)
danko davidovic
kondan is on a distinguished road
I am trying to mesh mid0-size complexity model. At the very end of meshing process, the Workbench mesher crashes with the following message:
ANSYSWBU.exe encountered a problem. A diagnostic file has been written:
C:\Users\...\ApplData\Local\Temp\AnsysWBDumpFile.d mp
I didn't go too far to nail down the cause of this error by reading the crash dump file (text editor does not help).
I am using ANSYS Workbench 12.1 version installed on 64-bit operating systems with Windowa Vista Business Edition (SP2) 2007 edition.
Don't know if it is software or OS issue or the size of the problem I am simulating (anticipated 7-8 million of cells).
Would appreciate any quick help on this, since I am already behind with delivering results of simulation.
Thanks.
amirokhovat and Pacific like this.
kondan is offline   Reply With Quote
Old   June 25, 2010, 04:11
sac
sac is on a distinguished road
You need to log this with tech support since they can get the *.dmp file analyzed to find out why it is crashing (this is a standard windows crash format file that can be debugged by using windbg).
Is this happening just with the model?
If it is happening more often usually crashes like this are associated with the graphics card and/or driver version.
sac is offline   Reply With Quote
Old   June 25, 2010, 15:50
danko davidovic
Thanks a lot for prompt answer. It happened couple of times with other models as well, but this time more often (maybe because of the size of the model).
I also read couple of posts where people associate this problem with graphics cards and drivers.
I think the best way is to send the .dmp file to be analyzed.
Thanks one more time.
Old   November 23, 2010, 11:29
Default AnsysWBU.exe error
Isack
lego is on a distinguished road
Hi kondan et al
Have you got the solution for this problem. I am facing the same.
lego is offline   Reply With Quote
Old   December 3, 2010, 11:53
Isack
Hi Fluent users. I have solved the problem. there was one folder named "wwwmoh_files" in drive H. I just CUT and pasted in drive D. It solved
Old   June 6, 2011, 08:25
godspeedwzw
just like wind is on a distinguished road
have you all solved the problem? I am using the ANSYS 13 and it still has the problem.
just like wind is offline   Reply With Quote
Old   July 26, 2011, 01:08
Darren Leong
Darren Leong is on a distinguished road
Hi guys,
I think I've isolated the problem to be a compatibility issue using workbench in windows 7 with an ATI card. Let me know if it's the same you all.
No solution yet found
Darren Leong is offline   Reply With Quote
Old   September 8, 2011, 14:10
Default solve this problem
amir okhovat
amirokhovat is on a distinguished road
Send a message via Skype™ to amirokhovat
Hi every body
I encounteredwith this problem and i solve it
You can install a virtual network adaptor ( i install microsoft loopbak) and regenerate license.txt and
amirokhovat is offline   Reply With Quote
Old   October 7, 2011, 09:12
Sal
Sal is on a distinguished road
Please see http://www.cfd-online.com/Forums/cfx...snt-start.html
Sal is offline   Reply With Quote
Old   October 8, 2011, 04:44
Darren Leong
Tested solution above for both ANSYS 12.1 & 13. It didn't solve the issue.
Local HPMPI and other components are running fine.
Old   October 10, 2011, 07:48
Sal
Hi Darren,
WB Meshing (v13) is working perfectly in my case.
Window 7 - 64bit in workgroup setting connected to Ethernet switch (no Internet access).
Hope you fix it.
Best of luck.
Sal
yasharif and Centurion2011 like this.
Old   October 31, 2011, 06:39
Emre G
emreg is on a distinguished road
i am having the same problem relating to this issue. Could you help me how can i fix it?
Thank you.
emreg is offline   Reply With Quote
Old   October 31, 2011, 11:43
Sal
Hi Emre,
Have you tried to install the System environment variable ANS_OLD_ATTACH = 1?
Advanced system settings / Environment variables
On System variables select -> New
On variable name -> ANS_OLD_ATTACH
On variable value -> 1
OK & Save
Try this and good luck.
Sal
J.Ramon, yasharif, emreg and 5 others like this.
Old   October 31, 2011, 15:02
Emre G
Thanks for ur reply.
Where can i find environmental settings in ansys, sorry i couldnt get?
Old   November 1, 2011, 01:35
Emre G
SAL, thank you very much.
Are u an expert?
The problem is solved according to your describing...
Old   November 1, 2011, 01:36
Emre G
Originally Posted by Sal View Post
Hi Emre,
OK & Save
Sal
anyway, i solved the problem by setting the new variables. On the other hand what does this solution mean? How did we solve it?
Old   November 2, 2011, 13:23
Sal
Emre,
this is the message you got:-
‘ANSYSWBU.exe encountered a problem. A diagnostic file has been written’:
C:\...\...\....\...\Temp\AnsysWBDumpFile.dmp
On the WB messages also it says:
‘Unable to attach the geometry file... An existing connection was forcibly closed by the remote host’.
Attaching geometry occurs if the mesh was created when the machine is on network (or connected to Ethernet switch).
To avoid this happening we simply set the environment variable ANS_OLD_ATTACH = 1.
Enjoy!
Sal
hmasenger, sozen and zhizhuo like this.
Old   November 16, 2011, 04:09
Regis
reggenzi is on a distinguished road
Thank you! It worked.
(Win7 x64, Ansys Workbench 13, nVidia GTX)
Hi Emre,
OK & Save
Sal
reggenzi is offline   Reply With Quote
Old   November 18, 2011, 15:31
Nin
Pedro
Nin is on a distinguished road
I'm facing this problem too. How can I install an environment variable?
Thanks!
Nin is offline   Reply With Quote
Old   November 21, 2011, 06:43
Regis
Thanks!
>>START
>>COMPUTER (Right Click)
>>Properties
>>Advanced System Settings
>>Environment Variables
Then
OK & Save
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
importing mesh from Gambit and other software to ansys workbench mortazavi CFX 12 May 30, 2012 07:38
importing mesh to ansys workbench??? mortazavi ANSYS 0 June 1, 2009 05:10
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 08:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
