December 21, 2009, 05:01 |
ICEM extrude mesh by rotation
Christian
Rep Power: 16 |
Hello everyone!
i'm trying to extrude a mixed quad/tri mesh by rotation around an axis. the model i want to mesh is a de laval nozzle which i want to simulate with 2d-methods. so i just want to create one layer of elements with a very small angle. the problem i'm experiencing is, that i always geht penetrating elements along the axis after extrusion. the only way i found to avoid this, is to translate the mesh away from the axis, rotate it and then translate back on the axis but this gives me an axis that isn't of infinitesimal thickness. i also tried to create one layer of quad-elements along the axis because someone told me, that tri elements on the axis doesnt work for extrusion by rotation but it gives the same results. has anyone an idea how to avoid those self-penetrating elements? regards, christian |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
ICEM CFD 5.0 - 2D to 3D Mesh Extrude | James Date | CFX | 7 | October 22, 2013 03:46 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
Hex-Tet Mesh Merge in ICEM | Tristan | CFX | 1 | September 26, 2008 05:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
