Home > Forums > Software User Forums > ANSYS
mapping CFD to FEM ?
Old   May 8, 2010, 09:33
Default mapping CFD to FEM ?
banakar
aerobanakar is on a distinguished road
Dear all
I want to know how I can export my data grid from ANSYS (FEM) to another CFD software ?
pleasea help me m as soon as possible
aerobanakar is offline   Reply With Quote
Old   May 13, 2010, 02:39
adminCAE
mechanicaldesign is on a distinguished road
Hi aerobanakar,
If you choose to export like .cdb export from ANSYS, maybe you can to import the mesh in other solve like CFD. I'm not sure, but try, and posted here if it works.
Best regards.
Mess with the best die like the rest ... ANSYS is the best !!!
mechanicaldesign is offline   Reply With Quote
Old   May 14, 2010, 10:06
Default THx
banakar
hello
Thx because of ur help
best regards
M. banakar(aerobanakar)
Old   February 12, 2012, 11:19
Default mapping
ssixr's Avatar
sudhir
ssixr is on a distinguished road
hey banakar,
i am also trying to map cfd data to fea...have u figured out any methods?
thank you
sudhir
Originally Posted by aerobanakar View Post
hello
best regards
ssixr is offline   Reply With Quote
Old   February 14, 2012, 02:26
Emre G
emreg is on a distinguished road
Originally Posted by ssixr View Post
hey banakar,
thank you
sudhir
follow this procedure:
-Open ansys workbench..
-set up any fluent case on workbench GUI
-at the same time, set up a structural analysis on the same screen. Read your mesh data for ansys meshing and built it.
-connect the solution data from fluent with FEM, which are placed on workbench.
- Start Mechanical FEM by selecting the FEM case.
emreg is offline   Reply With Quote
Old   February 14, 2012, 15:42
Far
Sijal
External Data Mapping
When results are to be shared between physics, standard practice is to import data, such as pressure fields, temperatures or heat exchange coefficients, from external files. Automated algorithms provide a very efficient tool to project the data from one mesh to another. However, some problems can arise in cases of misalignment between the original data and the current mesh, or when the initial data is too scarce. The capabilities introduced at ANSYS release 13.0 have been enhanced to provide users with additional control and correction capabilities in ANSYS 14.0.
http://www.ansys.com/Products/ANSYS+...ase+Highlights
Old   May 1, 2012, 23:18
ssixr's Avatar
sudhir
thanks for your reply emreg. but in my company we are using mechanical apdl as the solver not workbench so i cant follow the above procedure...And i am getting heatflux (temperature dependent data) from CFD group and giving temperature values for thermostructural group... CFD software used is FLUENT only..is there any way to apply CFD loads directly...
thanks
sudhir
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 10:51
Where to find comparisons of CFD FEM codes J.T. CFX 1 March 9, 2003 16:21
Where to find comparisons of CFD FEM codes Jen FLUENT 0 March 6, 2003 21:32
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
