fluent warning
Like Tree25Likes
Old   June 29, 2010, 05:51
Default fluent warning
ringtail is on a distinguished road
Dear all, I am getting the following warning while I import the mesh into FLUENT 12.1. The mesh is generated by ICEM CFD v12.1, and it is 2D.
Warning information:
130106 nodes.
129291 quadrilateral cells, zone 10.
257765 2D interior faces, zone 11.
155 2D wall faces, zone 12.
577 2D wall faces, zone 13.
196 2D wall faces, zone 14.
706 2D pressure-far-field faces, zone 15.
Building...
mesh
materials,
interface,
domains,
zones,
outer
flap
main
slat
int_solid
solid
Warning: Flow boundary zone 15 is adjacent to a solid
zone (10). This problem MUST be fixed before
solution can proceed!
Done.
Preparing mesh for display...
Done.
What should I do? Any one can help me?
thank you.
ringtail is offline   Reply With Quote
Old   June 29, 2010, 10:09
Luk
Geisel is on a distinguished road
Change solid into fluid
Geisel is offline   Reply With Quote
Old   June 29, 2010, 11:16
I have solved it. you are right.
thanks.
Old   September 2, 2010, 20:59
Rohan
tejas.khetani is on a distinguished road
Hey Ringtell,
Can you tell me where I am suppose to change Solid into Fluid???
I am asking as I am facing same problem as yours which says
Warning: Flow boundary zone 5 is adjacent to a solid
zone (2). This problem MUST be fixed before
tejas.khetani is offline   Reply With Quote
Old   September 2, 2010, 22:16
Originally Posted by tejas.khetani View Post
Hey Ringtell,
Problem setup --> cell zone conditions --> change the zone type of computation domain to fluid.
SAH, dale154, Nikoonz and 2 others like this.
Old   September 2, 2010, 22:56
Rohan
Thanks Man...It worked...
Old   December 4, 2011, 17:13
san
sandycbe is on a distinguished road
I am using fluent 6.3.26.. I am also getting the error Warning: Flow boundary zone 5 is adjacent to a solid
Can anybody help me in this...
Thanks in advance...
Abdulrajak Buradi likes this.
sandycbe is offline   Reply With Quote
Old   December 4, 2011, 17:24
Default sandycbe
Rohan
please try this one,....
Old   December 4, 2011, 17:33
san
but i cant find the problem setup option in fluent 6.3.26...
i dont know how to do that... can you help me in this...
Old   December 4, 2011, 21:06
Default sandycbe
Rohan
Hey this attachments might help you.
Abdulrajak Buradi and Nikoonz like this.
Old   December 4, 2011, 23:48
san
thank you tejas.khetani....
Old   April 23, 2012, 15:54
Justin Flanders
MetalSupremacist is on a distinguished road
This seems to be a simple solution. But what if the solid zone is actually suppose to be solid?
MetalSupremacist is offline   Reply With Quote
Old   December 25, 2016, 14:37
fahimeh
f.kh is on a distinguished road
sorry did you get the answer?
the solid zone of my computation is actually solid (Aluminum), so it is not logical to change it to a fluid zone, so what's the solution?
regards,
Fahimeh
f.kh is offline   Reply With Quote
Old   July 24, 2017, 21:52
Ajaysinh Solanki
solanki004 is on a distinguished road
Originally Posted by f.kh View Post
regards,
Fahimeh
Did you solve the problem??
Thanks and regards,
Ajay
solanki004 is offline   Reply With Quote
Old   July 24, 2017, 21:53
Ajaysinh Solanki
regards,
Fahimeh
Did you get an answer??
regard,
Ajay.
Old   February 27, 2018, 09:10
Punjab
Asjad is on a distinguished road
has anyone able to solve this problem? I am still getting this error
Asjad is offline   Reply With Quote
Old   May 26, 2019, 04:44
J HAN
han203 is on a distinguished road
The problem happened in the meshing process. Because you don't choose the right face as a boundary. If your model contains 3 bodies, and you have to choose and name a face in one of the bodies, you'd better hide the other two bodies so that you don't choose the wrong face. The flow boundary id is the wrong face you chose. Go back to your meshing software and rechoose the face, then there would be no problem.
han203 is offline   Reply With Quote
Old   April 8, 2020, 17:36
Thumbs up Thank you so much
  #18
Debdoot Ghosh
Debdoot_X is on a distinguished road
It worked!!
Debdoot_X is offline   Reply With Quote
Old   July 15, 2020, 11:58
Vignesh
Vignesh5710 is on a distinguished road
Hope this give better clarity!
Vignesh5710 is offline   Reply With Quote
Old   August 8, 2020, 11:02
PUTERI NURFARAH
Puteri Farah Taslin is on a distinguished road
hi. i cannot find the problem setup in my fluent. mine if 18.1.0 version. please help. thanks!
Puteri Farah Taslin is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Add icoLagrangianFoam to FoamX dyxu OpenFOAM Running, Solving & CFD 10 June 11, 2008 09:53
FLUENT Warning Jordi FLUENT 0 April 21, 2006 04:41
Warning 097- AB Siemens 6 November 15, 2004 04:41
