Need Help With ICEM Meshing
Old   October 12, 2010, 23:22
Unhappy Need Help With ICEM Meshing
gav
gav is on a distinguished road
As the thread title probably indicates I'm pretty new to ANSYS CFD software, and I'm having problems meshing my geometry models satisfactorily.
My model is a basic tyre inside a rectangular tunnel, touching the bottom and I need to mesh it so that the tyre can be set as a rotating wall later on. I managed to get the model to run once but since then I can't replicate it again and in the solver error always says there's something wrong with my mesh...
Firstly, I would like to have nice regular grid meshes on all of the surfaces of the model, which I can get OK, but then as soon as I try to add a volume mesh too the whole thing changes and I'm left with messy and irregular mesh structures. Can anyone give any advice on basic meshing methods? I would really appreciate some help.
Secondly, I can't get the mesh to work around the tyre contact point (the tyre is modelled as a basic cylinder, no depression at the contact point yet), the 'road' surface seems to meld into the tyre model which means I can't have a rotating wall. Has anyone done modelling of a moving vehicle or rolling cylinders before or know of any papers that could help?
I'm hoping my problems are really basic and someone can help, thanks in advance.
Oh and I'm using ANSYS 12.1.
gav is offline   Reply With Quote
Old   October 12, 2010, 23:56
gav
Here are some screenshots of what's going wrong
This is my current mesh, it looks really messy and there is a hole in the 'road' surface where the tyre is:
And so when I import into CFX Pre it looks like this and won't be able to rotate:
Thanks
Old   October 27, 2010, 16:30
Grant
grantom is on a distinguished road
Just a thought, but try meshing the tire and the wall separately to avoid them combining together at the interface.
Use the blocking strategy to mesh. Don't do a volume mesh fill from surfaces. Create the blocking topology and generate the mesh that way.
Hopefully this will send you in a better direction.
grantom is offline   Reply With Quote
Old   October 27, 2010, 19:54
gav
Hi Grant
Thanks for the advice, I did try to use blocking to mesh it but since I'm so new to this I couldn't figure out how to do it, I'm using an academic version at uni and we don't seem to have access to tutorials either.
I did eventually get this model to work, I changed the geometry dimensions around a bit and used basic octree tetra meshing which worked well with a bit of sizing. Not the structured mesh I was originally hoping for but it did the job.
Old   October 28, 2010, 08:34
Amir Khodabandeh
akhokhay is on a distinguished road
before changing anything first check where need to be changed
from the picture I feel that you have bad connection with ground maybe meshes in there are bad
Check for quality of determinant 2x2x2 and angle !
akhokhay is offline   Reply With Quote
Old   May 8, 2011, 10:15
Default interface
yi.ma
mayi85927 is on a distinguished road
how to use icem to build mesh and set interface? thanks very much for helping me.
mayi85927 is offline   Reply With Quote
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 21:02
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 08:24
[ICEM] Need help in ICEM CFD Mapped Meshing falconf16 ANSYS Meshing & Geometry 3 February 19, 2010 14:21
ICEM Meshing Jaloha CFX 0 April 1, 2008 06:24
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 00:34
