Flow does not go through nozzle???
Old   March 21, 2011, 17:53
Default Flow does not go through nozzle???
Nuril
nha1g08 is on a distinguished road
I am trying to simulate a 3d flow going through a nozzle, and into a chamber
Here is the geometry:
and here is the mesh
But when i run it in fluent i get the following result
The flow does not go through the nozzle, when i clearly defined the boundary condition for the outlet face to be a 'pressure outlet'.
Why is it not going out?
I also dont know why but the the same outlet face is defined by three faces, i set all three faces to be a pressure outlet. For example face 3, face 7, face 18 are in fact the same face as the nozzle exit. Could this be the problem?
nha1g08 is offline   Reply With Quote
Old   March 22, 2011, 12:27
Nuril
can anyone help?
Old   April 5, 2011, 17:21
Nickul's Avatar
Nick
Nickul is on a distinguished road
bit late but hey, You should set the outlet face to an interior, as it is now with the nozzle exit face set as a pressure outlet it is able to freely exit the domain, not what you want at that point. Make sure their is one face at the nozzle exit, or more accuratley one interior face common to the nozzle interior and your ambient domain, not two faces belonging to each volume on top of one another, then when coming from Gamble , fluent will turn them into walls.
Nickul is offline   Reply With Quote
Old   April 5, 2011, 18:38
Nuril
thanks for the reply Nickul, yes I did set it to interior and it solved the problem.
Old   May 6, 2011, 09:47
Zhiqiang Liu
Simon0114 is on a distinguished road
Hi,I'm making a project the same as yours,I set the boundary conditions refering to some papers,but the solution is always diverged,so can you give me some help on the boundary conditions setting,thanks
Simon0114 is offline   Reply With Quote
Old   May 6, 2011, 11:31
Nuril
hello, are you trying to simulate vortex rings?
Old   May 6, 2011, 21:13
Zhiqiang Liu
no,I just simulate a 3D flow through a nozzle,mainly simulate the flow in the ambient,the ambient was simplified to a cube,just as a chamber like yours
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Flow pattern in a Nozzle sean Main CFD Forum 0 February 2, 2009 04:36
Nozzle Flow Simulation Winnie CFX 0 August 24, 2007 10:10
Compressible flow in the nozzle Saturn FLUENT 2 November 29, 2004 04:22
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
