Flow around formula car
Old   December 9, 2011, 01:28
Default Flow around formula car
tetsuya
srad is on a distinguished road
Im now analizing flow around formula car, especially on under the vehicle often called floor, undertray or underbody.
I got a result showing negative force(downforce)on floor and as a hole vehicle.
But the analisys was done with k-ε.
Turned on k-ω, then I got positive force as hole vehicle, almost 0 force on floor.
I can under stand flow separation occurs stronger on k-ε, then downforce will be decreased.
One model with k-ε shows similar downforce to experimantal data, but when with k-ω, shows lift force!
Another with k-ε shows too much excessive downforce, but with k-ω, shows similar to experimantal data.
All the surface under the body is meshed as prism layer, and others are tetra.
Is this a problem?
Or are there other problems?
I can't resolve this problem for a long time!
Please help me. Please.
srad is offline   Reply With Quote
Old   December 10, 2011, 02:57
AeroSuresh
aero_suresh is on a distinguished road
Dear Srad,
the following reference may be useful.
http://www.fisita.com/education/cong...a2010scp11.pdf
which deals with car conceptual design using k-e model.
Don't forget to say thanks and click 'like' if you really like it.
AeroSuresh
aero_suresh is offline   Reply With Quote
k-ε, k-ω, prism, vehicle
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
3D Supersonic flow over a car TeQuiero_Q8 FLUENT 0 August 13, 2009 03:42
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Flow field analysis around the car Cenk FLUENT 1 December 26, 2003 18:09
Simulation of Car Cabin Air Flow Erwin Susanto Main CFD Forum 0 May 19, 2000 11:33
