Problem with gas inlet in an external flow
Old   January 30, 2012, 06:35
Default Problem with gas inlet in an external flow
Vitor Monjardim
vitor.monjardim is on a distinguished road
Hi everybody!
I'm working on a gas dispersion from a tube that is in a table. My problem is that the soft isn't recognizing the end of the tube as an inlet, even when I named so. I've tried to enclosure it; tried to name the table has a solid and the tube as fluid and then encloruse it; tried to build the environment without using enclosure, but at the end, in all of them, the fluent isn't seeing the surface has an inlet.
Just to know, the table has 70mx70m, 30m high and the tube has 0,2m of diameter.(the problem could be with the dimensions, because the diameter is too small??)
Does anyone know how to solve it??
Thanks!
vitor.monjardim is offline   Reply With Quote
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 05:12
steady RANS for flow problem with unsteady inlet? kat Main CFD Forum 0 February 16, 2009 10:24
Reversed flow on external aero problem Ben FLUENT 2 August 22, 2006 10:05
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
