February 11, 2013, 07:22 |
Change of flow area in summary planes
Bjorn Fejer
I would like to ask for help regarding my Simulation on CFD 2013, my problem was the flow area of summary planes is different from inlet to outlet even-though I used same inside diameter of pipe. I have tried to move the cut planes, still they are having different in flow area.
I have used water for incompressible fluid. My parameters is as follows Inlet=10 Bar pressure Outlet=6 m/s velocity Thank you in advance. Bjorn Fejer |
February 18, 2013, 18:36 |
Mark Decker
Rep Power: 13 |
The area calculated is based off of the mesh topology. It is not uncommon to very small errors, especially for a coarse mesh due to the faceting and some round-off error. Refining the mesh helps the accuracy, but based on your flow vectors, your mesh seems OK. It should not be as far off as you show.
Flow Rate over general area | Lubos | OpenFOAM | 0 | April 2, 2011 05:53 |
Boundary Flow and Total Force Summary | amod_kumar | CFX | 0 | January 12, 2011 23:26 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
flow dimension change | susan | CFX | 6 | December 19, 2002 09:03 |
