Home > Forums > Software User Forums > Autodesk Simulation CFD
Temperature Limit for Cooling System
Old   November 7, 2016, 11:13
Question Temperature Limit for Cooling System
Ryan Huang
huangyuan18 is on a distinguished road
I am currently running a simulation with a chilling coil in an inlet cooling system. I simplified the chilling coil as a combination of heat generator(negative value) and resistance.
Problem arises at low speed areas where the air can be as low as -30 degrees. This is certainly not the case in real life.
I wonder if anyone has experience setting temperature limit in the heat exchange simulation? or are there any other models that suit my case better?
Really appreciate the help!
Ryan
huangyuan18 is offline   Reply With Quote
Old   December 21, 2016, 06:57
Jon Wilde
W!ldejon is on a distinguished road
Are you simply using a resistance with a negative heat gen? Or the Heat Exchanger material?
W!ldejon is offline   Reply With Quote
Old   December 21, 2016, 10:15
Ryan Huang
Thanks for your response. I was using a resistance with a negative heat gen. As far as I know heat exchanger is mostly used as external heat source, but in my case it is internal.
Old   December 29, 2016, 03:18
Jon Wilde
Yes, the are really designed to be used externally. If you use them internally, you need to use a flag to be sure that the inlet and outlet flow rates are consistent with one another.
Check this out: Heat Exchanger Mass Balance
I tend to just use a resistance but it depends on the goal.
cooling rate, heat exchanger, heat generation rate
CFX error: "enforce system memory limit" controls whether this is a fatal error windfire CFX 12 March 23, 2020 08:15
Temperature limit reached axry FLUENT 4 December 5, 2015 09:33
unexpected constant Temperature on a clip surface Sungki OpenFOAM Running, Solving & CFD 0 August 4, 2015 04:50
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
