Home > Forums > Software User Forums > AVL FIRE
zero faces in dynamic mesh
Old   December 1, 2013, 02:25
Default zero faces in dynamic mesh
shahrbanoo
shahrbanoo is on a distinguished road
Hi...
I want to make a moving mesh for my SI engine
I did it with fame engine plus
after it has finished, I tried to give the .flm file data for case, but I noticed that I don't have INI_EX_Port.
and I then found that I didn't have any face on outlet part, for example, the faces of BND_Outlet and all faces related to outlet are zero.
Could u please help me?
Best regards...
shahrbanoo is offline   Reply With Quote
Old   December 1, 2013, 07:20
shahrbanoo
please I need the answer...
Old   December 2, 2013, 04:11
Myunghwan Kim
kimmhw is on a distinguished road
If your Fame Engine Plus is working well, I guess re-mesh generation will be better.
Surely, your surface file should include the selections.
Otherwise,
I think you can use FMO Editor.
After opening *.fmo, you can see many moving sets.
And then, you have to load one mesh for each moving set and define selections and save mesh. You have to repeat this process for all of moving sets.
kimmhw is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
Mesh elements shape on faces Mohsin FLUENT 3 August 17, 2011 02:37
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
