February 16, 2016, 17:02 |
Fire-chemkin
amin u3fi
Hello everybody,
I faced this ERROR and the calculation diverges when I use FIRE-CHEMKIN mode. Please let me know what you think about it. %fire-I-chom_rate, Calling Solver for Homogeneous Reactions %fire-I-chom_rate, progress of ODE solution = 20% %fire-I-chom_rate, progress of ODE solution = 40% %fire-I-chom_rate, progress of ODE solution = 60% DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.1340237082787D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.2487341268969D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.2487341268969D-21 DVODE-- Warning: internal T (=R1) and H (=R2) are such that in the machine, T + H = T on the next step (H = step size). solver will continue anyway In above, R1 = 0.1459500094191D-03 R2 = 0.2487341268969D-21 DVODE-- Above warning has been issued I1 times. it will not be issued again for this problem In above message, I1 = 10 %fire-I-chom_rate, progress of ODE solution = 80% %fire-I-chom_rate, progress of ODE solution = 100% DVODE-- At current T (=R1), MXSTEP (=I1) steps taken on this call before reaching TOUT In above message, I1 = 20000 In above message, R1 = 0.1459500094191D-03 %fire-I-cysetup, ==================================== Testing proper position of injector: |
August 12, 2018, 07:01 |
iman pourmousavi
Rep Power: 12 |
Hi AMIN
I have the same problem as you.could you help me? Thanks , IMAN |
how to find distribution field of reaction rates when CHEMKIN is enabled? | EdgarasM | FLUENT | 1 | February 18, 2019 09:41 |
Car park ventilation and impulse fans | guillaume | Phoenics | 9 | October 27, 2015 05:57 |
Convert CHEMKIN file (.inp or .dat) to .f suffix for AVL FIRE | amin_u50 | AVL FIRE | 3 | May 3, 2013 04:00 |
Question on CHEMKIN INTERFACE | Rui Yang | Phoenics | 7 | January 30, 2002 04:04 |
Temperature errors on fire simulation? | raymond | Siemens | 0 | January 10, 2002 20:32 |
