Home > Forums > Software User Forums > AVL FIRE
Meshing Problems
Old   April 26, 2021, 10:44
Default Meshing Problems
Deutschland
freyp is on a distinguished road
when i extrude a volume is there a way to separate the edges with wich i start from those edges of the extrude volume ?
The Problem occurs, when i want to extend a nozzle for making a volume out of the extended part, wich doesn`t work because i cannot span the volume without extending my original nozzle, because the edges are not separate.
Maybe someone has already worked with the example injector of AVL FIRE M and is able to help me out.
Thanks in advantage
freyp is offline   Reply With Quote
Old   May 6, 2021, 17:00
Lukas Kutej
delsolman is on a distinguished road
you can define selections on your edges... highlight them and do copy paste... by this way you get new edge mesh which contains only the edges from your selection.
to extrude mesh in one direction you can define face selections on outer face, activate only this selection and do enlarge extrude. after that you have to join both meshes and perform conform connect.
delsolman is offline   Reply With Quote
avl fire help example
[snappyHexMesh] Problems meshing an impeller with snappyHexMesh kandelabr OpenFOAM Meshing & Mesh Conversion 13 June 9, 2017 06:18
[GAMBIT] Problems while meshing a 3d CAD model CFDST ANSYS Meshing & Geometry 28 January 7, 2013 01:52
[ICEM] Problems with meshing of wind turbine Dosis ANSYS Meshing & Geometry 14 November 13, 2012 05:41
Problems of Icem meshing about Conical Forebody raja2010 ANSYS Meshing & Geometry 2 December 6, 2010 09:20
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
