August 9, 2000, 04:48 |
cell layer (de)activation
hello,
i wanted to know if it is possible in star to activate/deactivate cell layers depending on the vertex position of a moving mesh (which in turn is moved depending on the pressure) thanks in advance! |
August 10, 2000, 04:49 |
Re: cell layer (de)activation
Try to read tutorial 7 and 13 in the STAR-CD tutorials online manual. Goodluck =Ahmed=
August 16, 2000, 06:24 |
The problem is, that as far as I know, a cell layer can only be (de)activated at a given time (events, you know). As I don't know in advance at what time a certain vertex is going to be at a certain position, I actually don't know when to switch a cell layer on or off. So if it were posible to use for example conditinal events to 'translate' a vertex position to a special time where I could (de)activate a cell layer, that would solve the problem, I guess.
August 16, 2000, 07:23 |
You can set the events according to a prespecified time, position of a coordinate, or prehaps a field pressure. You can get an idea of the events file by editting the file prep.inp in tutorial 7 or 13.
August 16, 2000, 07:27 |
thanks, I'll check on that..
November 3, 2000, 15:28 |
when set the event, you use command evstep evno , time , specified-time if you use other parameters, such as degree, instand of time, the star can translate the degree into time
Create a layer of cell above ground of 1m tall | sammi | FLUENT | 0 | August 11, 2008 00:34 |
First cell height - boundary layer | Vincent | FLUENT | 2 | May 20, 2005 14:54 |
CHT cell layer thickness problem | Arnab | Siemens | 1 | March 13, 2005 08:36 |
about activation energy | fanadam | Main CFD Forum | 2 | June 24, 2002 13:26 |
about activation energy | fanadam | Phoenics | 0 | June 23, 2002 23:08 |
