Building solid cells
Old   November 21, 2000, 17:47
Default Building solid cells
kerem pekkan
Hi, I have just started tutoring STAR-CD. Currently my project group is working to model a simple rectangular duct problem. We are trying to model two parallel solid plates by marking some cells as solid. That is to say; solid partitions are build by cell modify method.
However when we BUILD SOLID CELLS AFTER MESH REFINEMENT (i.e. by modifying the refined cells as solid) model set-up is found to have CRACKS at the modified solid region. Producing [Error 74]. We may be missing some switch related to mesh refinement since all is normal if we refine cells after building solid partitions.
Thanks everybody in advance for posting comments and sparing time.
kerem
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
Solid cells on symplane boundaries samu Siemens 7 May 29, 2006 10:07
Unresolved & Problem Cells of Solid Type Harry Siemens 1 August 2, 2005 15:11
Temperature profile in Solid cells pramod Siemens 3 May 30, 2005 13:56
Flow through solid cells Julie Polyakh Siemens 1 September 6, 2003 08:18
