how to calculate the flow rate through a surface
Old   February 14, 2002, 08:17
Default how to calculate the flow rate through a surface
july
hi... Anybody knows how calculate the flow rate through a surface... is there any facilty in Star cd to do that?
Old   February 14, 2002, 08:29
Default Re: how to calculate the flow rate through a surfa
Stephan Meyer
Use the *get command with option tas or tav (type "help *get" in prostar command line for detailed information).
Old   February 15, 2002, 05:34
Daniel
Another option is to load the flux results via the GETCELL, FLUXSUM command, initialize the flowrate via FLUXSUM, INIT and the pick the faces through which you need the flux calculated via FLUXSUM, CROSS or FLUXSUM, ZONE. The result appears in the output window.
Old   February 15, 2002, 07:06
july
thank you Daniel...
How to calculate particle mass flow rate at outlet Randy FLUENT 6 April 29, 2020 13:47
[OpenFOAM] How to calculate the fluid flow through a surface lynx ParaView 4 January 20, 2016 11:58
Flow rate through a surface Imraan FloEFD, FloWorks & FloTHERM 2 June 24, 2008 02:26
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 19:38
flow rate through curved surface john Siemens 0 February 13, 2004 01:01
