Ignition problem (ICE modelling)
Old   August 13, 2002, 03:58
Default Ignition problem (ICE modelling)
hennie
Hi, I'm modelling flow in an IC engine with spark ignition. The Weller model is used for combustion, but when the required time step for combustion is reached, the following warning messages occur, and, looking at the solution(Temperature, Scalar conc, etc.), no combustion takes place.
*** WARNING #042 *** PROCESS NOT FULLY CONVERGED -- EQ.,NIT,RESI: SC1 1 0.88906E-06
*** WARNING #043 *** MINIMUM RESIDUAL AT THE END, RETURNING NON-CONVERGED SOLUTION
Can anyone PLEASE help.
ignition problem Parthiban Siemens 0 May 17, 2008 02:33
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Fan Modelling Problem in CFX Jenny CFX 8 September 11, 2007 13:59
Chem. Reaction and Ignition Setting in ICE Problem Tulus Siemens 0 March 28, 2005 00:02
Ignition problem Julie Polyakh Siemens 0 January 29, 2002 05:39
