December 4, 2002, 05:35 |
Heat flux on a irregular surface
hello, In order to obtain the heat flux through the wall of the casing of machine at a given section, I should create a set of vertex on the exterior casing but the casing is not a regular circle.
I would create a set of vertex on a inner circle and then I would move them to the external casing. I can create the vertex set but I can't move them as I would like. How can I get it? |
Applying Heat Flux out of the surface in CFX | Ijaz | CFX | 3 | February 26, 2009 16:33 |
Total heat flux vs surface integral | Al | FLUENT | 0 | December 22, 2008 12:16 |
constant surface heat flux | Andrew Hayes | Main CFD Forum | 4 | March 16, 2006 07:19 |
surface heat flux | joe | Phoenics | 1 | November 30, 2005 05:34 |
Estimating Surface Heat Flux | M.Lakshminarsimhan | Phoenics | 2 | September 2, 2003 05:24 |
