How to change the reference pressure value to 0 Pa
Old   June 28, 2003, 19:15
Default How to change the reference pressure value to 0 Pa
Lee
I want to change the reference pressure value from 1.0e+05 Pa to 0 Pa when I run a model,in the "monitoring and reference data" I tried to change the reference pressure value into 0 Pa,but when I typed the "apply" buton,I found the reference pressure data value always to return to 1.0e+05 Pa.
So,I want to know whether I can change the reference pressure value,if possible,how can I do?
Thank you very much for your help!
Lee
Old   June 30, 2003, 05:34
Default Re: How to change the reference pressure value to
John
This is probably a design erro - but as a fix, you can use a very small non-zero value such as 1.e-05
Old   July 1, 2003, 00:32
Lars Ola Liavåg
The thing is, the reference pressure value needs to be input as absolute pressure and if you set it to 0, you basically specify perfect vacuum; hardly a condition where the Navier-Stokes equations apply anymore... Perhaps CD have put a limit on purpose?
Regs,
Lars Ola
Reference pressure Fernando Herrera Main CFD Forum 0 August 21, 2008 11:41
Reference Pressure shashank Siemens 0 April 5, 2007 15:48
Reference Pressure Prabodh V.K. Siemens 2 December 24, 2003 01:30
Reference Pressure Danard CFX 2 November 12, 2002 14:11
reference pressure Martin Nilsson FLUENT 2 December 15, 2001 17:16
