graph transient post data at sensor point
Old   July 9, 2003, 11:14
Default graph transient post data at sensor point
Micha
Hi, I would like to graph temperature over time at a defined sensor point. Transient calculation is already done and pstt-file is available. I tried already commands gload and gtrans, but I must have an error in the syntax. There is always a message comming up saying "ERROR, Graph Register can't be greater than 7". Unfortunately information about graph transient data are quite spare in the manual. Can anyone give me the correct command syntax? Thanks. Micha
Old   July 10, 2003, 09:52
Default Re: graph transient post data at sensor point
Pauli
The error message is telling you that you are trying to put data into a graph register which is not available
Issue the command 'memo mxstor xxxx' then issue the command 'numreg xx' to set the memory space required to hold the data you which to graph.
The command numreg sets the number of columns you wish to use in the graph registers. The number of rows is mxstor/numreg.
Note: You must issue the greset command before you can change numreg
Old   July 11, 2003, 09:15
Default exacter problem describtion
Micha
Hello, I think I should once again describe my problem more exactly. I tried to use the advices of Pauli, but that doesn't help.
As said I want to plot temperature at a special vertex over time using the data in my pstt-file.
Therefore I first defined a sensor at this vertex. Then, I used the following commands to load the wished data into the graph registers:
gload,1,sensor,all,1
gtrans,case.pstt,getv,next,1,add,all
t,absolute
You can see in the output file, that Prostar loads well the first, lets say three time steps. But then it produces the mentioned warning for all other time steps.
In the graph registers, you can find the following data now:
1.graph register, 1.row: Vertex number of the sensor-vertex
2.graph register, 1.-n. row: Iteration numbers
3.graph register, 1.-n. row: Timesteps
4.graph register, heading: T for vertex number, 1.row: correct value for the first time step, 2.-n. row: there is written "non" !!????
5.+6.+7.: heading also T, 1.row: 0 and nothing else.
Where does the value (=0) in register 5+6+7 come from? It seems to me that Prostar tries to load some more value than just the temperature I want to get.
Would be great if someone can help.
Cheers Micha
Old   July 11, 2003, 11:27
Default Re: exacter problem describtion
Anton Lyaskin
Which version of ProSTAR do you use? This is a bug and it first appeared in v.3.10b - the system tries to put data for each time step into the next graph register, not into the next position in the same register. I think there is a patch correcting it, you should contact technical support and ask to send it (at least for me they did it).
Old   July 11, 2003, 11:29
Micha
Hello Anton, thanks for this advice, I'll contact support. Have a nice weekend. Micha
Old   July 30, 2003, 12:29
Micha
It was indeed the version of STARCD which had a Bug....
Old   March 20, 2013, 04:17
Elaine Wee
bubuchacha is on a distinguished road
Hi Micha, im am currently trying to plot a graph temperature vs time step. Can you guide me how to plot the graph? Im using FLUENT Ansys
bubuchacha is offline   Reply With Quote
saving transient data for 1 point & 1 variable REH CFX 8 November 24, 2015 16:09
Graph for a sensor in transient conditions Bill Siemens 0 February 8, 2007 04:27
Transient Post Data file *.pstt Tony Siemens 3 October 27, 2005 07:28
Post-process: how to extract Graph Registers' data Jiaying Xu Siemens 11 July 17, 2002 04:38
Post-Processing Transient Data Clinton Lafferty FLUENT 1 March 19, 2001 07:24
