What is this status message
Old   July 30, 2003, 00:29
Default What is this status message
David Baker
When I use Generate Mesh in Aerodynamic Mesh Wizard I get this message and program stop.
"MesgGen 1 of 2 - Holding for Available Processor"
How can I solve that?
Thanks,
Old   July 30, 2003, 10:41
Default Re: What is this status message
cjtune
You probably selected, under your mesh generation tab, to split your model into multiple (in this case 2) subdomains for mesh generation. This is a feature only in the newest ProAM (and ES-series) where you can split mesh-generation jobs between multiple CPUs and hence do it much faster (or with less memory with a single CPU). Should be harmless unless it hangs for a very long time. You should check your process listing just in-case.
Old   July 31, 2003, 01:25
Askmat
Hi
Can i do this split meshing using PRO AM release 521 or does it require a parallel version of PRO AM also
Old   July 31, 2003, 02:54
cjtune
I'm not sure if there's a 'parallel' version of ProAM but the subdomain meshing works on r521 on my single CPU machine using the existing license for r519.
Path status in DPM BC UDF HS FLUENT 4 June 12, 2014 07:12
Status of FV versus FEA research in CFD diaw Main CFD Forum 8 February 11, 2005 00:52
VOF status Paul Main CFD Forum 6 June 30, 2003 20:26
What's the status of Unsteady design of Turbomachi Ji Lucheng & Chen Jiang Main CFD Forum 0 December 24, 2002 03:44
Viscosity and equation status Mir Siemens 3 June 13, 2002 13:39
