October 23, 2003, 04:08 |
large executables-mandrake 9.1
Hi
I'm have 1.5GB of ram and I'm having a bit of a problem with executables greater than about 700MB, they don't run. I either get a segmentation fault or if I starlink -Y then the executable is not created I get the error message /usr/bin/ld: cannot find -lc. I'm using Absoft v7.5 compiler with both patches. Has anyone any experience of this? Thanks Allan |
October 26, 2003, 05:51 |
Re: large executables-mandrake 9.1
Obviously, the libc is not found. Either it is not installed or the linker cannot find it beacuse the path ld is looking to for finding the libraries is wrong. Please check both.
October 26, 2003, 11:41 |
Hi
Thanks for the reply. I got fed up with mandrake and other problems I've had with large exe's and sementation faults, so I installed SuSE, which CD recommend, and everything works fine now. Allan |
Parallel Fluent with Mandrake | Daniel Dotta | FLUENT | 1 | May 19, 2005 15:30 |
Linux Mandrake v9.1 | allan | Siemens | 2 | October 6, 2003 14:56 |
CFX 5.6 on Mandrake 9.1 -success | matej forman | CFX | 1 | August 15, 2003 19:40 |
softwares required to build local executables | Danie | CFX | 9 | June 11, 2003 03:51 |
Need liscense to run star executables? | Jiaying Xu | Siemens | 4 | September 21, 2001 08:14 |
