segmentation fault
Old   January 9, 2004, 06:14
Default segmentation fault
natesan
While trying to run a problem in star solver, I am getting an error message like 'segmentation fault'. Can any body advice me to resolve this difficulty. Thanks in advance
Old   January 9, 2004, 09:02
Default Re: segmentation fault
Richard
It could be anything - kernel limits, shell limits, a bug in your user subroutines (if you have them), a bug in STAR itself, a bug in the compiler. Contact your STAR support office with this problem.
Old   January 9, 2004, 09:57
Joel
star throws those segmentation faults up fairly regulally, you just have to watch and find out what you or it is doing at the time it comes up and then try and change it.
Old   January 11, 2004, 23:30
natesan
Thanks for your help. The same problem is running without any trouble when I make all the cell types with 'no radiation'. Could you now guess what could be the problem in my model.
Old   January 12, 2004, 08:51
nicola
Problems with radiation are especially in transient calculations hard to solve. Ask your support, they will solve your problem...
[Technical] Segmentation fault in map msg30 OpenFOAM Meshing & Mesh Conversion 6 March 27, 2008 10:49
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 22:57
segmentation fault tipakorn Siemens 6 July 31, 2006 07:56
Segmentation fault Veebs Siemens 3 June 4, 2002 22:17
Segmentation fault Jose Sanchez Siemens 1 December 16, 2001 08:13
