parameter NCMAXV OR NBMAXV
Old   February 13, 2004, 04:34
Default parameter NCMAXV OR NBMAXV
Frederik
after running a computation with heat transfer with constant molecular properties, I want to switch to user coded properties. When I try to restart now, the message is: *** ERROR #210 *** INSUFFICIENT DIMENSIONS FOR THE MOLECULAR VISCOSITY ARRAY.INCREASE PARAMETER NCMAXV OR NBMAXV AND RECOMPILE.
Using the command MEMORY shows, that there are no such parameters.
Any hints are welcome - Frederik!
Old   February 13, 2004, 04:45
Default Re: parameter NCMAXV OR NBMAXV
Frederik
So I found that the parameters are listed in the parm.inc file. After changing it successively to a number that is far above the number of my model's cells, the error still prevails. Still, any hints welcome ...
Old   February 13, 2004, 07:28
Richard
You should re-write your geometry and problem files. If there is now a file called parm.inc.new, move it to parm.inc. Then do starlink again (on UNIX) or just rerun STAR (on Windows).
Old   February 16, 2004, 06:52
Frederik
Thank you for your answer, I tried your suggestion. There was no parm.inc.new file written. By the way, everything works if cp (SPECHT.F) is user coded, but fails with conductivity (CONDUC.F) and viscosity (VISMOL.F). I also manually changed the values for N(C/B)MAXV in parm.inc to something 10times the number of my cells. This doesn't work either. Is there any documentation on such issues (parameters and sizing) availlable?
Old   February 16, 2004, 08:48
Richard
You shouldn't have to edit the parm.inc file by hand, so there's no documentation on these parameters. They should be invisible to you. If you have tried what I suggested in my last posting and it does not work, you've probably found a bug. Contact STAR support.
Old   February 16, 2004, 09:44
Steve
If version 3.2 ever gets released, these problems should be a thing of the past.
Old   February 17, 2004, 22:42
http://www.excitecity.com/forum
Old   February 21, 2004, 05:32
lxyz
Edit your parm.inc file to set NCMAXV=NCMAX and NBMAXV=NBMAX. If your heat conductivity option is not selected as constant, you may need to set NCTMXC=NCTMAX ans NBTMXC=NBMAX as well.
Good luck !
Old   February 23, 2004, 08:28
Frederik
I did all of this, it doesn't work I have the impression that the error message itself is misleading.
two parameter on the same plot ammi reddy FLUENT 0 March 22, 2007 22:47
Kinetik parameter for CO + 0.5 02 -> CO2 Martin CFX 0 January 26, 2006 08:30
using parameter with gambit tone FLUENT 0 October 3, 2005 09:41
NFMAX parameter Sileno Phoenics 2 January 12, 2005 04:42
Penalty Parameter Kai Kang Main CFD Forum 1 March 13, 2001 03:38
