HELP!!! part2
Old   June 7, 2004, 10:55
Default HELP!!! part2
LORENZO
I have to read a table with eleven dependent varibles. I store it with eleven columns plus two columns for independent variables but there is a warning saying that more than ten variables are impossible to read. How can I store the table. Where do I have to write the eleventh column in .tbl file?
Old   June 14, 2004, 14:02
Default Re: HELP!!! part2
4xF
If you look at the output of the online help (by pressing the F1-key) concerning the command TBREAD (which does the same as reading a table input from the GUI), you will find the following line:
<DVAR1 DVAR2 DVAR3 .........DVAR10> (DVAR="dependent variable") <VAL11 VAL21 VAL31 .........VAL101> (up to 10 DVARs per line)
This means that you will only be able to read *10* dependent variables. This value is hard-coded, so there is no chance that you will be able to read the 11th dependent variable.
2N Storage Runge kutta-part2 vasanth Main CFD Forum 1 August 6, 2005 13:16
Re:Developing windsurf boards (part2) Sander van Essen Main CFD Forum 0 February 13, 2001 03:31
Developing windsurf boards (part2) Tiesda Main CFD Forum 1 December 7, 2000 21:35
