star is not running the simulation in windows
Old   July 31, 2004, 19:40
Default star is not running the simulation in windows
Arnab
Thanks for the help. Now I did as u guys said abt running star from windows and i selected user sub routines and also moving mesh case.
In the star-CD launcher it says "Running stat" but where can I see the process running?
Also in the C:\WINNT\system32\cmd.exe window it says warning : command execution error please check screen output for details
starin.f compile error
exiting starlink
f77: error switch f is ambigious
what is the problem and how can i get it fixed though it says running star. is my program running? is the simulation going on in the back ground?? Thanks in advance.. Arnab
Old   August 2, 2004, 02:40
Default Re: star is not running the simulation in windows
F.K.
You should install the fortran compiler.
Running FLUENT in batch mode for Windows OS Jake Lee FLUENT 7 June 29, 2016 08:38
Problems with Gambit running on windows xp pro Carlos Ruiz FLUENT 1 February 27, 2009 05:04
STAR-CCM+ , Re-Running same simulation MAB Siemens 4 September 29, 2008 04:17
problems of running SGI codes in windows baal Main CFD Forum 1 August 16, 2005 22:16
