egrep command
Old   September 13, 2004, 12:02
Default egrep command
Julie
Does somebody know how to use the command egrep for extracting the needed values from a file (.info file, for example)?
Regards,
Julie
Old   September 14, 2004, 13:34
Default Re: egrep command
steve
egrep is very similar to grep - did you try
man grep
to see the parameters?
Type something like
grep ITER file.info
for example to find all lines containing the string ITER in the file file.info
Old   September 14, 2004, 17:05
Jörn Beilke
http://www.adapco-online.com/adapco_...ices/tips.html
Have a look at the second script.
help on a command.. Vasilios FLUENT 0 January 23, 2008 08:53
egrep command Julie Main CFD Forum 1 September 14, 2004 14:07
-> (command) Vasilios Papaioannou FLUENT 0 March 29, 2004 06:18
Text command of monitor-command? Mika FLUENT 0 March 27, 2001 13:46
PIL command Mehdi BEN ELHADJ Phoenics 1 February 7, 2001 08:03
