output image quality
Old   January 14, 2005, 07:34
Default output image quality
Ted Crilly
hi there, star-cd users,
i'm using star 3.22 in win xp environment, and looking to output some vector sectional plots at high resolution,
in pro-star i can go to utility save screen as and choose:
gif ps eps format files, but the quality is not very good,
when i zoom up in my image the vector arrows are blurred and not clearly defined, is there a way i can create a higher resolution image.
thanks for any help offered
regards
ted
Old   January 14, 2005, 15:33
Default Re: output image quality
Brian
Use the Postscript (eps) output. It's vector based and should be able to zoom in pretty far.
But you'll need a Postscript viewer to view and print them - Google for Ghostscript for a free one.
However, a better way is to create your plots using the TERM,,FILE method. This creates a neutral plot file, and you can create .gif files from that at any resolution you want.
Old   January 17, 2005, 06:10
Ted Crilly
thanks brian,
i was able to plot to file, creating a .plot file, and open this file up in motif neutral plot, plot xm in utilities and print a ps file in high quality,
thanks for the help
cheers
-ted
ParaView 330 image saving and image copy ma436 OpenFOAM Bugs 1 February 5, 2009 03:13
Star CCM - Problem with image hardcopy quality James Siemens 2 March 14, 2007 02:36
can "output control " output Nu in expression? prayskyer CFX 3 July 7, 2006 19:37
Image uploading zxaar CFD-Wiki 6 September 15, 2005 17:36
High Quality Image from Fluent Mike FLUENT 4 September 7, 2005 07:41
